Old 03-10-2010, 08:03 AM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
Default Top loader adjustment shifter handle
Hello All,
I have a Toploader with the shifter ring on the base. I am also using the bent shifter handle with my setup. I am noticing that when I place my trans into reverse or into 4th the handle hits the ring.
Do they make shifter ring with a larger opening or do I have to grind a notch in the handle to except the shirt.
It is able to go into gear but if I dont put enough force which is not much it will pop out of gear.
I also tried moving the ring over a bit but I then have problems with 1st gear
Any thoughts?
