Originally Posted by dcdoug
What's the main benefit of the secondary metering block and the second idle mixture screw, by the way?
The short answer is "if you car runs well, then there is no benefit to a secondary metering block."
Secondary metering blocks let you change the jetting, but if your metering plate is "just right," then there's no point in changing anything. Personally, I like my 4160 along with the metering plate (which has non-adjustable metering orifices). 4150s also have dual accelerator pumps -- some people love that. BTW, some people just think that mechanical secondaries are inherently superior to vacuum secondaries, but I am of the opinion that a properly tuned vac secondary is just as good, and sometimes better, than a mechanical setup. Two idle screws are needed because there are two idle squirters for the two primary venturis -- (some carbs have four). Two are easy to adjust, and you move them in unison. I use a vacuum gauge, and have for decades, but I'll readily admit that an gizmo in your sidepipes to measure the burn is superior.
