Old 03-12-2010, 09:21 AM
dcdoug's Avatar
dcdoug dcdoug is offline
Do Kirkhams have the same frame as CSX cars? I was able to remove my Canton pan. Just clears the cross member as long as the rods are up for the rear cylinders. I did it without a lift too. Which pan do you have? I have heard Aviads won't clear though, although maybe you could if you loosen the motor mounts and raise the engine a bit. Hopefully someone with a kirkham will chime in.
www.partskeeper.com
