Old 03-12-2010, 09:31 AM
Z-linkCobra's Avatar
Z-linkCobra Z-linkCobra is offline
Cobra Make, Engine: Everett Morrison, All aluminum small block ford.
If you have a 2 pc rear main then yes you can remove the pan, drop the rear main cap and replace the seal. If you have a one piece seal then you will have to pull the tranny. Im not that up on the 427 so I dont know about the rear main...that you will have to find out.
" If it wont break em loose in 3rd gear, it aint enough power "
