Originally Posted by FWB
oh the return line!!!!! there should be two ports. one is right above the t-stat housing the other on the same face as the t-stat housing on the right. if they are missing you can drill and tap the manifold
Actually the waterpump line is the return line, the manifold one is the feed. That way the temp gets to the heater before the thermostat opens.
