Old 03-15-2010, 05:24 PM
FWB's Avatar
FWB FWB is offline
thanks ken, but i must say the 160 degree t-stat will make the engine be cooler on a hot summer day for about 40 seconds longer than the 180. after that i would recommend the temp gauge be put on a toggle switch. it can be turned off then the motor will be running at zero degrees, problem solved lol
