Old 03-15-2010, 05:42 PM
wrogers55's Avatar
wrogers55 wrogers55 is offline
Cobra Make, Engine: Backdraft #318, 418 CI, 532 RWHP, Mass Flow Injected, TKO600-Road Race, BMW M3 Suspension, Race Springs (Wouldn't do it again, rough on the street).
Default Clutch Fork Setup Help Needed?
I'm finishing up a new clutch install on a 418w, McLoud C&PP, scatter shield which is big, heavy and ugly, pivot ball on the passenger side, push type slave cylinder. I'm ready to put the throw out bearing and clutch fork in place and button it up.
All my experience is with open wheel transaxle cars and I need a little comfort here. I assume I want the throw our bearing to be just short of touching the PP fingers and the clutch fork arm to be parallel to the flywheel. Or maybe I should say, coming out of the exit hole in the shield straight, not leaning toward the front of the car or back.
Does it make sense to angle the fork very slightly toward the front, knowing the clutch is going to break in some and the PP fingers are going to back up some, moving the arm a bit backward? That makes mechanical sense to me, but maybe it's not necessary and is nonsense anyway.
I'm having to do this on jackstands under, so any help with technique would also be greatly appreciated. That shield bucket is stupid heavy.
It's finally 72 here today and I really need to get this done!
Thanks for all the help.
Wayne Rogers in Hideaway, Texas
