Need FFR owners advice please
Days away from FFR order placement and need help. Want to build a daily driver on a 20K budget. Car will probably never see a track or rally. Just occasional street race and pleasure driving around La Crosse, Wisconsin. I expect to order a hard top w side curtains to maximize use here. Engine will be W351 350-400 HP range. Have not decided on carb or EFI yet. I would appreciate your opinions on this engine choice/HP range, carb vs EFI for my intended use and budget. Also, can someone recommend a source for good hard top add on. I expect to order cutouts, Lucas wipers, heater defroster & seat track. Can these be sourced cheaper if non FFR? Need opinions on bumpsteer tie rod ends, rear coil over option and rear tubular upper and lower contro arms. Finally (whew) are there other options I should consider? Thanks.
