Originally Posted by Mooch
Which part? The "buy the best that you can afford" or the "Don't over do it on the horsepower"
Really, both. But between those two pearls of wisdom I would say the "don't overdo it on the horsepower" is the more important. I say that because the impact of "overdoing the horsepower" will act as a subtle psychological deterrent to driving the car. It will actually take away from the enjoyment, rather than adding to it. While buying a little less car than you can afford will generally just whet your appetite for the next level up -- which is a good thing. With a car that only weighs 2500 lbs. or less, anything even in the 300+ horsepower range is going to be plenty. 400, more than plenty. 500? C'mon.
I don't think any of us with even the weakest FEs on the road can stand on a WOT above 3000 RPM and slowly count to three on the street. And with most of the big block builds coming out of the well-known builders on this forum you can't stick WOT at all without busting your rear loose.
