Thread: FE Timing
  #36 (permalink)
Old 03-18-2010, 08:38 AM
undy's Avatar
undy undy is offline
The lack of cranking capability could be a separate issue, not tied to the ignition timing. ...not saying it is either, but i could be inadequate wire size, defective/inadequate starter/relay or a poor ground to mention a few.
I've seen used balancers reused by engine builders before, jus' covering all the bases. I wasn't saying YOUR engine could have a leak, just the engine that the balancer "could" have been on in a previous life. I was just descibing things that typically kill a balancer.
As said before it's "normal" for it to run better (to a limit) the further you go BTDC.
As Pat said, you're probably at a point you need to return it to the builder.
