Old 03-19-2010, 05:43 AM
mikeforte mikeforte is offline
Smile Speedo gear
Hi Ed,
You'll need a 20.7 tooth gear for your speedo. Knowing a 20.7 tooth is impossible you can install a 20 tooth gear which the speedo will display higher speeds or a 21 tooth gear and your speedo will display a lower and more accurate speed.
Forte's Parts Connection
40 Pearl St
Framingham, Ma. 01702
fortesparts.com
508 875 0016
In 1993 Mike made the first conversion of a Ford Tremec to GM 5-speed. It bolts to stock bellhousings w/out an adapter. The FE Tremec, the Mustang adjustable quadrant are originals from Mike.
One of 12 Tremec Elite Distributors worldwide for: T-5, T-56 Magnum & TKO-500 & TKO-600 ,Midshifter, Frt shifter, offset Vette shifter.
Est: 1981 selling performance parts to build your dream car...
