Old 03-19-2010, 08:31 AM
DonC's Avatar
DonC DonC is offline
Cobra Make, Engine: ERA #684, 428 FE, TKO600
I've had mine since 05 and have put about ten thousand miles on it. A nicely put together unit. I tow with an 04 Ranger V6 and my total package with the car loaded is about 4500 lbs. Never had a problem and it tows very nicely. The only thing I would do different is get aluminum ramps. They weren't available when I got mine but I'm going to upgrade.
Larry Johnson is easy to work with if you're going to order new.
A great alternative to a full size trailer if you don't have a large pickup to pull the heavier full up trailers. No problem maintaining highway speeds. Could use an extra 50 hp when pulling up long steep grades (but who couldn't) but as long as I don't have to slow down for someone in front of me can maintain 70 going up.
DonC
