Tire Balancing Beads
Any one ever hear of balancing tires using ceramic beads inside the tires? I was over at the Porsche site and they gave an example of dumping 3.5 oz of the beads in the tire before sealing it on the rim. Inflate the tire and drive away. No lead weights on the rim. You can not use any fix a flat or tire sealer as it will clump the beads.
Coments????
 Snakebit
