Thread: Tire rub
Old 03-19-2010, 11:44 AM
AZ Pete AZ Pete is offline
Cobra Make, Engine: FFR
You should be able to turn the spring seat by hand when unweighted, as jhv48 said. First, however, check that the small set screw on the seat is loosened. If it won't turn by hand, insert a metal pin or drill bit into one of the holes in the seat for a better grip. My Mk3 with same front tires is 4" at lower frame tube.
Pete
