Old 03-19-2010, 04:44 PM
392cobra's Avatar
392cobra 392cobra is offline
6th Generation Texan
Originally Posted by Snakebit View Post
Any one ever hear of balancing tires using ceramic beads inside the tires? I was over at the Porsche site and they gave an example of dumping 3.5 oz of the beads in the tire before sealing it on the rim. Inflate the tire and drive away. No lead weights on the rim. You can not use any fix a flat or tire sealer as it will clump the beads.
Coments????
They are big with the Harley crowd.
Dyna Beads offers Tire Balancing Solutions
Wheel weights have been around for many years, but are no longer the only solution for trucks, commercial vehicles, trailers, aircraft and motorcycles. We want you to get the highest possible tire mileage by using our products.
The way we do this is by offering a Dynamic Balancing Solution, a high-density ceramic bead that, when easily installed, continuously balances your tires as you drive. The amount of material will distribute itself in weight and position dependent on the balance requirements of the individual tire.
The result is a smooth, vibration-free ride, derived from our balancing media that is always repositioning itself as the tire wears. If you own a pickup truck, commercial truck, motorhome, RV, tractor trailer, motorcycle, or similar vehicle, and want to get rid of those wheel vibration and tire cupping problems, then you need to move up to Dyna BeadsŪ!
http://www.innovativebalancing.com/index.html
