Thread: Roller CAM -FE
  #62 (permalink)
Old 03-21-2010, 03:24 AM
PANAVIA's Avatar
PANAVIA PANAVIA is offline
OK, an update. 03-21-2010 -- I finally got the 428 in the engine run stand and tried to fire it up. The original iron boat anchor heads were returned to the vendor long ago.
I installed a set of Edelbrock Performer RPM cylinder heads, and matching intake. I wanted this to look like a stock ford ( of sorts) so I took the extra step of milling off the edelbrock script on the intake and painting it blue.
Ignition; Summit has a great little distributor with a gear that is good for roller or iron use.
what I am having problems with now is the rocker arm spacing , position and geometry.
I bought a set of smith bros push rods to go with my Comp cams Roller FE rockers, however they -the rockers- the end girdles do not fit under the "COBRA -LEMANS" cast aluminum valve covers. in addition edelbrock performer RPM heads move the valve positions in such a way that the stock comp cams roller rockers setup will not readily align with the pushrods and valve stem tips.
Not to mention the push-rod clearance work I had to do to the intake. add this to the problem where a few of the adjuster nuts on the roller rockers were not threaded all the way, and backed off during run in. (will put up pic of inside of adjuster nut. )
When the nut backed off it allowed the pushrod to gall the bottom end of the rocker(s)
More news when it happens. -- on the phone with Comp Cams monday.
Steve
