Thread: Roller CAM -FE
  #93 (permalink)
Old 03-21-2010, 03:39 PM
FUNFER2's Avatar
FUNFER2 FUNFER2 is offline
Well, this is quoated from the site. But, pay special attention to the
"SPECIAL NOTE" at the bottom. That now concerns me, very much.
COMP Cams® Solid Roller Lifters
Endure-X™ Solid Roller Lifters are fully heat-treated, machined to ultra-high tolerances and fully rebuildable.
All models feature EDM Oil Injection™ technology, which ensures that the roller bearing assembly receives a constant flow of pressurized oil. This virtually eliminates needle bearing oil starvation, historically a “problem area” for all solid roller lifters when used in low rpm and street applications.
COMP Cams® Super Roller Lifters are available for a variety of applications, including small base circle camshaft and offset pushrod seat configurations.
Endure-X™ Solid Roller Lifter Features
1. Patented link bar assembly combines the benefits of a removable link bar with the safety of a captured link bar.
2. EDM Oil Injection™guarantees that the bearing assembly receives a constant flow of pressurized oil via a precision hole aimed directly at the needle bearings.
3. Precision Sorted Bearings -distribute loads evenly, preventing premature wear and failure.
4. Tool Steel Axle -prolongs the life of the roller assembly, particularly in high rpm applications.
Special Note: Solid roller lifters are designed for use in racing applications; however if used in street applications precautions should be taken to avoid excessive idling and certain engine builder modifications are required. Low RPM usage may result in a lack of lubrication from windage, premature wear and ultimately extensive engine damage.
Regards,
Kevin
