Old 03-22-2010, 02:36 AM
Barry_R Barry_R is offline
Hi Tom
I take all my aluminum head/ARP stud combinations to 90 pounds with ARP lube. I take the bolt combinations to 95 pounds. Fasteners get washed and test fit - if they don't thread in glass smooth they get wire brushed and fiddled with until they do. Washers get lubed and installed under either fastener. Fel-Pro 1020 gaskets go on perfectly dry, installed on surfaces wiped clean with thinner or brake cleaner.
So far I have had exactly two Fel-Pro 1020s fail since they came out - one where the customer was using a factory 427 head that had been milled beyond belief - the deck of the head actually collapsed. The other had a piston tag the head - not sure how he did that since we had at least .040 clearance (free rotation checked with no gasket installed).
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
