Old 03-23-2010, 06:16 AM
EarlsflyinCobra's Avatar
EarlsflyinCobra EarlsflyinCobra is offline
Ouch Ouch Hot Sand
Cobra Make, Engine: Street Beasts w/302 Twin Turbocharged....Under Construction!!
Send a message via AIM to EarlsflyinCobra
the battery got weaker and weaker
I have been keeping the battery on a trickle charger and have been trying to keep an eye on it as I go.
The coil sparks when the ignition is first turned on and sparks, with a beep coming from the distributor, once or twice when the ignition is turned off.
Fuel was a problem as I had a regulator that would only put out 7 psi, I have since changed it and now have 45 psi.
The plugs are not sparking.
I'm going to double check
Where are you pulling the switched 12 volts from? This is the source for the small red wire on the MSD box, not to be confused with the heavy Red & Black wires that actually powers the MSD. It has to be HOT with 12 volts while cranking and in the run position. Without that you are dead in the water.
and see exactly where this is routed to tonight when I get home. I think I have checked this but now am second guessing myself
Safe Flyin, errrrr Drivin, Earl
