Old 03-23-2010, 09:15 PM
dlotz dlotz is offline
Default refund offered....
Originally Posted by Woodz428 View Post
Those would have been junk if FEs hadn't gained so much popularity. I wouldn't trust anything that guy says, he apparently knows nothing about heat expansion...everytime the rockers hit those hot valves they'd split a little more. I would be surprised if they weren't cracked enough already to grab that sweet little bronze liner and stuff it into the port.....just enough to cause the valve to hang open some...maybe enough to touch a piston. What a butt wipe.
The shop is a pretty big name here on most of the forums. I contacted the seller and they did agree to refund my origional purchase price.
Only issue is that I already had to send the heads back to them twice at a cost of $400 ($300 for additional labor, $135 in total shipping.) Once to repair a small cosmetic crack that I discovered after removing the paint and the second to replace the valve seats that were all at different heights causing the stems to locate all over the place.
It appears the valves were cut down in order to help get all the valve stems close to the same height which was my origional complaint with the valve seats being at different heights.
