Old 12-28-2001, 05:00 PM
olaf herrick olaf herrick is offline
Default Does this motor rebuild sound fair?
Hey guys, I 'm hoping to get your opinion on the price I was quoted on rebuilding my 427 SO. $3900 it includes keith Black pistons 10:1 $700, rings $180 filefit, solid roller lifters $400. roller cam $370 , 8 intake valves $144, all bearings $200, gasket set $190. push rods $180, rocker shafts $190, mag crank and rods, hone to 10 over, turn down crank 10-10, assemble heads and seat new valves, assemble motor. check line bore and deck. set up and dial in new bellhousing and balance motor externally. The motor was a race motor and was sleeved completly and is 12:1 at 7 over currently, the 428 crank is virgin, the heads were flow ported already and oil passage work is already done. The timing chain and oil pump are already new and the heavy duty rod bolts were already installed. What do you think ? I looked in PAW and the parts prices were high on some items, 2700 parts and 1200 labor . Thanks for any input you can give me .Olaf
