Old 12-28-2001, 05:51 PM
Jeff Frigo's Avatar
Jeff Frigo Jeff Frigo is offline
Cobra Make, Engine: ERA 454 S.O.
Doesn't sound too bad, but do you really want to go with a solid roller cam? If you do, you need to pull the lifters out every 3,000 - 4,000 miles to check for wear on the needle bearings in the rollers. If one lifter comes apart, you will have all of those needles going through your motor destroying evrything.
Jeff
