I have custom made them for specific applications like Craigs set up also. If you have a 4 into 4 flange that can be a helpful part. Michael you don't have a flange obviously yours are slip fits, with your car if it's high on one side and low on the other you can loosen the motor mount nuts and twist the motor to a better position for side pipe alignment effectively splitting the difference between sides.
