Originally Posted by FrankJohnson69
Dan, I have an ERA with a smooth hood. My intake is an old Holman & Moody medium riser with 600's on it. the only thing you will have to worry about is the rear molded bracing on the hood that will just barely touch the air cleaner. Just trim that back (neatly prior to painting) about .25" and you will be good to go. If you'd like I can send you pictures measurements or what ever you need.
Regards,
Frank
Frank - from looking at your photo gallery that intake actually looks pretty tall. Bob P. sent me some photos of a medium riser with the air clearners sticking up in the hood scoop about a 1/2 inch, maybe 3/4 inch. Sounds like you found the right combination. Did you mill the carb pad any?
Dan
