Old 12-29-2001, 07:21 AM
cobrajeff's Avatar
cobrajeff cobrajeff is offline
Tony -
SWEET looking set-up! Is that an Accusump forward of your expansion tank?
You're CHOKIN' your carbs for air! Two things - I think your air correctors should be more like 185 or 195; and you're losing probably 25-30 ponies thru the air cleaners.
My engine runs so poorly with air cleaners on, I don't use them. I believe that if you want to run the air cleaners, the carbs should be jetted and tuned to run with them, otherwise, it runs too fat and loads up.
There are lots of guys here that know more about them than me, but, I think you'd be headed in the right direction by upping your air correctors. Good luck!
regards,
cobrajeff
CobraJeff
ERA P 202
