Old 03-28-2010, 01:17 PM
Gatorac's Avatar
Gatorac Gatorac is offline
Cobra Make, Engine: BDR 930, 427 Windsor T56
Question Differential, rear suspension question ***BDR specific***
I have 181 up on the lift now and I have noticed something that seems odd. The trans output shaft is centered in the frame rails perfectly. The differential is not. It apears the entire rear suspension sub frame is offset to the right by 1/4" and turned slightly. This makes the driveshaft offset to the right by 3/4" It also makes the differential input at an angle on the horizontal axis.
I understand that the drive shaft shouldn't be straight from the trans to the diff in the vertical.
Anyone have any input on this? Is your BDR like this?
Jim Pomroy
Have Fun!
BDR #930
08 Corvette Coupe
92 Sunburst Yellow Miata
#81 Saturn V Miata Crapcan racer
Panoz GTRA #42
