Also, small point, but on a MK III the mirror is shipped uninstalled, only the mounting bracket is put on at the factory so the mirror is installed and adjusted by the "dealer".
The mounting bracket can only be installed one way for the mirror to face reward, so the issue is with the mirror installation and adjustment. I am sure the existing mirror can be rectified, but will still send you a new unit that you may use (or install on the right side if you choose) so that you may be completely satisfied with your SPF!
rick@autoventureusa.net
