  #124 (permalink)
Old 03-30-2010, 07:25 PM
PurpleVenom's Avatar
PurpleVenom PurpleVenom is offline
Cobra Make, Engine: FFR MKII - 460 Crate with Cobra Jet heads, 750 Quick Fuel Carb, and Edelbrock Torker II Intake port matched to heads
My .02 worth - the aluminum fender liners - I know you like the raw aluminum look, however, a few trips on the road and you will find it's a lot more work to keep that look. I used an undercoating and find it's a lot easier to wash that down than polish aluminum.
Fresh air for the footboxes - soooo if the intake is right by the radiator - want it be hot at stoplights from the heat off the radiator?
Brakes - how would you like the potential for 1,200 lbs pressure at the calipers with 30 lbs pedal pressure? Drive my car next time I see you, maybe I'll ride over to your place after you pickup the car, which is.......when?
Love the attention to detail and the color will look great with those polished pipes. Looking great Deano!
