  #42 (permalink)
Old 03-31-2010, 08:22 AM
ztarum ztarum is offline
Cobra Make, Engine: Superformance #2731 (now sold)
Default Another way to fix the mirror
I had the same issue with mine. To fix it I loosened the screw at the front all the way and remove the reflector. You can then unscrew the bullet shaped housing from the pedestal mount. Now, drill a new mounting hole in the bottom of the bullet, so the bullet rolls to a more appropriate angle (trial fit first to find the position you want) and resecure. Reinstall the reflector, and you're good to go.
This will all be invisible as the mount pedestal will still cover the old hole in the bullet. It will then work as well as any tiny mirror can.
