Thanks Rick and George , do either of you know if I can use a Hydrolic lift cam and lifters to acheive my desired 500+ HP with my 2X4 setup (1200 cfm)? I want a lobby cam but I dont want alot of hesitation from the line. I will check with the machine shop Monday about the pistons( and ask for Forged ones) , I heard previously that Arias pistons were of very good quallity but pricy. The bore is currently 7 thousands over and with a Hone they plan to acheive the desired 10 thousands over. The machine shop said one rocker shaft was cracked. The previous owner cracked the 428 crank , an intake valve and 4 roller lifters. I found a non-machined 428 crank and they are suppling the other parts. Thanks Olaf
Ps. Do intake valves take more of a beating than exsaust valves in race applications?
