Old 04-01-2010, 07:58 AM
ERA Chas ERA Chas is offline
Chas. did you mean in the actual AN fittings themselves or just where the fittings then go in to the remote adaptors? There's no tape in between the AN stuff. Sorry for the confusion.
Yeah, that's better and I feel better about Doug and the gang. That's the pipe side. NOT thinking it looks cool, I always trim the exposed tape off after installation-unless I can't reach in the installed place.
You may not like the oven cleaner bit as when finished it leaves a dullish, somewhat oxidized look. If you try to wire wheel to remove it, that will gall the fitting. Just replace with Aeroquip nickle if it bugs you.
Chas.
