Old 04-01-2010, 03:48 PM
Woodz428's Avatar
Woodz428 Woodz428 is offline
Cobra Make, Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
Originally Posted by Roush #1 View Post
The condition of the cylinder walls and the bore - is it standard bore or has it been previously bored to the max - will weigh heavily on the value of the block.
NOS means New Old Stock, an unused piece that was never in service. If it is NOS, there are a few FE builders around that still have some for sale, you might check with them to see what they are asking. I think the price mentioned in the earlier post is probably close. I'm not sure how the price was affected by the influx of all the aftermarket blocks. Since some have the C5 casting code and are much stronger, that should have made their value stabilize. A ribbed block is set up to use hydraulic lifters and has plugs under the rear oil passage plugs in the valley. Left in it is for solids, removed they will run hydraulics.
WDZ
