Originally Posted by strictlypersonl
The I terminal is powered through the light whenever the ignition switch is on. In the original Ford circuit, there was also a shunt around the bulb to allow a bit more current, but we've found that the shunt is not necessary if you rev the engine over 1000 rpm at startup.
Is a SHUNT the same as a RESISTOR? I went to radioshack for the SHUNT and this is what he suggested:
http://www.radioshack.com/product/in...ductId=2062310
