Old 04-03-2010, 10:11 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
the bend not be bent and line up correctly----in other words--if the angle of the water pump outlet and the radiator inlet are not in the same plane, you will never get it to stay on unless you put a second bend in the tube to match the second angle
