04-04-2010, 09:58 AM
GA
Cobra Make, Engine: Butler Cobra. 350 Chevy Engine, blueprinted, heads cc'd, ported, polished, manifolds matched, big valves, 1.6 roller rockers, TB Injected, mild cam, MSD crank trigger electronic ignition. TKO-600 transmission. XKE Jaguar rear. IFS by Fast Cars
Originally Posted by RICK LAKE
lal Naja Art Have you looked at the super richmond 5 speed? The shift location is in the same place as the trans you have. The trans mount is 1" back of the trans you have. If you are looking to use the orginial shifter, it works nice. If racing I run a short shifter to the trans. This trans is good for the 600/600 rating.
No, I have not considered the Richmond. I think the external shifter linkage could present a whole new set of problems. In my application and you can see my trans/Hurst shifter on page three of my Photo Album in my Public Profile. It's mounted with a custom bracket to bring it forward. The Butler has the engine/trans pushed back as far as it can physically go. I guess I could create something that would do the trick, but internal shifter looks like a better engineered solution?
Thanks,
Arthur
