Originally Posted by patrickt
After a thread last year on having to tighten the pressure plate bolts in an aluminumn flywheel (which you do through the clutch fork hole and you have to bump the engine over a few dozen times before you get the bolts lined up right)...
Not to hi-jack your advice to dc but would you mind explaining this one to me? I have never heard of anyone torquing (or is it retorquing after installation?) f'wheel bolts through the fork hole. I can't imagine getting a torque wrench in there much less getting an accurate reading.
I have only done p'plate bolts on installation, obviously with the s'shield and trans out. If it can be done, I think it's corner-cutting and is not smart or safe but I would stand corrected if it's common professional practice.
Still wouldn't do it though...
