Same problem, both motors, broke the roller off the lifter and several other lifters had the needle bearings gone. Second motor broke two lifters, both motors had a little over 1000 miles on them. When I contacted CC they said with the spring pressures I was running, the life of the lifter was 800 miles and 1000 miles for the springs. I spent a couple of the winter months calling different manufacturers. When I contacted Crower he asked if I was happy with the spring pressure I was running and I said yes, he then said continue to use it, and you won't have any problems, and they won't have to be rebuilt like others. They were right. I've also had a CC cam fail in yet a different motor. BTW I'm running 210lbs closed and 620lbs open pressures. Whenever my engine builder even mentions using something CC, I tell him give me my parts and I'll go elsewhere. The new engine has Ohio Crankshaft rotating assembly in it. Tall deck Dart block, and Dart 18 degree heads.
Jack
XSSIVE .....
