The thing is , you could use the 95A Gen 3 Motorcraft and be ford-o-riffic at the same time.
Andrei -- one should not be using an AMP gauge that is UNDER the rating of the ALT.
in the case of the SPF, the AMP rating is 50/+/- -- whereas the 10SI 1 wire is atleast 90A.
