Thread: Dead Cylinder
Old 04-12-2010, 01:37 AM
Gaz64's Avatar
Gaz64 Gaz64 is offline
I'd be doing a compression test first to rule out the engine.
Then I'd swap two carbs around to prove the fault to one barrel of the suspect carb.
Airflow of 5 compared to 10 of the rest does not sound good, could be a twisted throttle shaft or idle air issue.
Gary
