Old 04-12-2010, 09:45 PM
Keithc8 Keithc8 is offline
The N-heads do work well but like said above you will need the right guide plate and Ford racing makes an off-set intake roller rocker for them or you can run a shaft system which is kind of expensive for street engines. Like mentioned why don't you just do some of the aluminum heads and make it easy on yourself.
Good luck, Keith
Keith C
