Originally Posted by Tom Wells
I'm not sure you understood my sarcasm about this pan. For the 460, it does not work! Oil pressure goes to zero regularly, even in modest turns. I consulted Canton about this problem, made all the changes, inspections and adjustments they recommended and it still didn't work. I checked pan-to-pickup clearance, trap door operation, tried different oil fill levels and more. Don't know about the small block.
I'd save my money on this pan and use the money for something else.
The Accusump does seem to work fine.
Tom
Thanks, Tom.
Oh, ehe. Sarcasm? Well, I'm not always awake... Anyway- there are those who say I should switch to the Canton sum w/ pick- up.
I'm currently using the OE pick- up, and as you may know, home-made kickout, baffled & trap doored sump. Some say the OE pick-up is trash. I don't know.
Nice to know the (Canton) Accusump works. What I'm considering now is if I should plumb it to the rear or the front of the engine; does it matter??? (The World block have aol- gallery plugs at more than one location in the block).
Rune
