  #33 (permalink)
Old 04-13-2010, 08:22 AM
jhv, instead of going through "all that" why didn't you simply put a return spring on it and solved the problem in the first place? I'd rather follow a clutch manufacturers specifications than an SPF builder. If those guys have never seen a throw out bearing fail, there are not doing any serious mechanic work. It is likely their customers drive less than 500 miles a YEAR.
I'm I the only guy here that actually DRIVES his car? If your only going to put 500 to 1500 miles on it, yeah, DUH, the throw out bearing isn't an issue. I've got 20,000 on mine...
