Old 04-14-2010, 07:19 AM
john chesnut john chesnut is offline
I cheated when it comes to the parts!! I built the semi-monoque chassis. I designed it to take the suspension cradles from the C5 Corvette. The cradles are aluminum and have the lower suspension pick up points, sway bar mounts, diff mount and steering mounts built it. I only had to fab the upper aframe mounts. The wheelbase and track are the stock C5 Z06, so the geometry is unchanged from the Vette. The Vette uses a transaxle. My car does too. I shortened the torque tube and moved the engine rearward 22 inches to achieve a 54% rear weight. The engine is an LS6 hooked up to the 6 speed manual transaxle. Total weight is right at 1900lbs. I am having fun!
