Copy/Paste from the SAAC "Open Track" info pdf. I will arrive on Thursday, leave Monday. I'm in the garage.
Ernie
SECTION 3 — PADDOCK ACCESS / PADDOCK PARKING
Infineon has a limited amount of paddock parking. Spots will be available on a first come/first served basis.
Please use as little space as possible. Once you find a spot and set up you will not have to move for the entire
convention. All paved surfaces must be protected. Participants must use flat blocks or wood squares to absorb
weight beneath any equipment that may cause damage to the surface, such as jack-stands and trailer legs. No
holes will be permitted and any asphalt surfaces including but not limited to the racing surface, pit area and the paddock area.
The track will be available at 5 p.m. on Thursday, August 26 for load-in until about 7 p.m. It will open at 7 a.m. on Friday,
August 27 and 7:30 a.m. on Saturday August 28 and Sunday, August 29. Once you go through registration and get a
wristband it will not be necessary to go back there again; you can just drive right into the track.
