What is an engine plate? Since you call it a throw back are you suggesting they did not work well? I understand if you have poly mounts you don't need the chains, but if you had original rubber mounts, would the chains be a reasonable add-on? Oh, maybe you are saying if you are worried about your motor mounts, don't mess with the chains and use poly? Thx
