Not that hard to do (I also had to put a hose from the breather to the Air Cleaner to augment the existing PCV setup). There are plenty of inexpensive lightweight breathers out there with a hose nipple for just this purpose. Then get a 90 deg (or other) plastic fitting that you can attach to the bottom of your filter housing--I think I got mine from Summit Racing. Then drill a hole in the base of the housing, attach the elbow (so that it does not interfere with throttle/choke/carb/filter function), insert one end of the hose on the fitting and the other on the nipple on the installed breather, and you are in business with a closed-loop system.
I think that I found the plastic elbow fitting at Summit Racing under air cleaner accessories.
Good luck
Bill
"If your work speaks for itself, don't interrupt"
