Originally Posted by Double Venom
Cpt,
The rear bolts go all the way through the 2x2. I think the head of the bolts are welded to the tracks so it should only take one guy to get them out?
License Plate: Did a Nut-Zert pull through that thin area of the trunk? I was going to cut a slot from the bottom of the latch and mould in a steel plate! Ran out of time when we put the bracket on.......... Afraid it was going to be a problem.
Fuel tank- did you solve that one?
John, CPT Eddie doesn't have the stock seats!
1) Ok I got under the car and see the 4 bolts holding each seat in. I'm going to see if I can get the Kirkey to fit and get some more leg room.
2) Yes the nut-zert failed. I think I can use longer bolts and go straight into the trunk. Otherwise I'll re-glass it and start over.
http://www.flickr.com/photos/49338317@N03/4524164158/
http://www.flickr.com/photos/4933831...n/photostream/
