I think the battery drain was caused by something else. I've driven it so several times since the incident and haven't had a problem since. It probably won't cut out again until I get her into a heavy traffic condition (stop and go). I did change out the ignition switch as it was cheap and easy. I've also purchased a magnetic pickup for the distributor and will change that out next.
After a good hard ride.....oil pressure is over 50, temp is below 190, she idles and no new dents. LIFE IS GOOD!
