Hi John,
I have 30 new 8.8" Ford 3.73 rearends in stock. I narrow them and can supply 5 lug axles & brakes and make them the width you want starting at $1610.00.
Call me with any questions.
Originally Posted by MaSnaka
DV or anybody else who might know, I have the 8" rear end on my CR. It's also known as the baby 9. I need to make some repairs or up grades and want to consider an upgrade to an 8.8. Currently my 8 has a limited slip but needs rebuilding, also it's got 411 gears which I want 3.75 or 3.50 also drum brakes which I want disc, and the housing may have a slight bend in it. Since all these items add up to fix $$, I'm thinking of going to an 8.8 or 9". I have 57 1/2" from the inside wheel to the inside wheel or brake drum to brake drum. What rear should I be looking for or are all the upper and lower arms, shock mounts all custom installed to fit the CR? Or is the rear a direct bolt on unit that fits the CR, from a specific year car or truck? Thanks for your replies.
John
Forte's Parts Connection
40 Pearl St
Framingham, Ma. 01702
fortesparts.com
508 875 0016
In 1993 Mike made the first conversion of a Ford Tremec to GM 5-speed. It bolts to stock bellhousings w/out an adapter. The FE Tremec, the Mustang adjustable quadrant are originals from Mike.
One of 12 Tremec Elite Distributors worldwide for: T-5, T-56 Magnum & TKO-500 & TKO-600 ,Midshifter, Frt shifter, offset Vette shifter.
Est: 1981 selling performance parts to build your dream car...
