Old 04-17-2010, 08:55 AM
lal Naja's Avatar
lal Naja lal Naja is offline
Cobra Make, Engine: Butler Cobra. 350 Chevy Engine, blueprinted, heads cc'd, ported, polished, manifolds matched, big valves, 1.6 roller rockers, TB Injected, mild cam, MSD crank trigger electronic ignition. TKO-600 transmission. XKE Jaguar rear. IFS by Fast Cars
Originally Posted by Excaliber View Post
5 1/2" is a good call for the street, speed bumps, parking lot ramps, man hole covers, yeah, it's a good call.
Have you cut the bottom off your bell housing? That is generally the lowest part of the car. I broke my trans mount from hitting speed bumps with the lower portion of the bell housing. Since I cut off an inch or so it makes a BIG difference!
Good idea, I had not considered it before. It is a McLeod Steel unit and cutting off some of the bottom flange should not be a problem. I think I'll loose one bolting hole if I do.
I'll check this later today when I get to my shop.
Thanks,
Arthur
